Keyboard encoder for the smallest keyboard — Parallax Forums
Graham StablerGraham Stabler Posts: 2,510
edited 2006-10-24 20:31 in Propeller 1
Some of you may remember that I made a housing for my demoboard, TV and keyboard to fit in a tiny flight case only to discover that the USB keyboard I had purchased was USB only and would not work with the adapters I had used with other keyboards. I discovered that there is sometimes a boot mode that allows the USB keyboard to work in a limited fashion in bios on a PC which could make interfacing easier however I couldn't get confirmation from manufacturer so I'm not going to risk the time and effort.
What I am left with is an array of switches going into a nice edge connector so I thought it might be a better bet to program a keyboard encoder to provide PS/2 from the keyboard.
I have found detailed info on the keycodes and the expected actions from the keyboard:
www.computer-engineering.org/ps2keyboard/
And full details on the PS/2 protocol:
www.computer-engineering.org/ps2protocol/
And of course the keyboard object that comes with the propeller has most of what is required, the keycodes, sending and receiving routines etc.
I'll have to work out the mappings between the edge connector and the keys but I'm confident it could be relatively straight forward and would do two things, provide me with the smallest keyboard I can find for any propeller apps I do and also provide some base code for anyone else who wants to make a custom keyboard for the propeller or even a PC.
If anyone has already done this or has a better idea please let me know.
Graham
The smallest keyboard in the west, out of its case and resting on the parallax micro keyboard. Its a Keysonic micro BTW, have seen these at very low prices.
  • Graham StablerGraham Stabler Posts: 2,510
    edited 2006-10-21 14:46
    I have been looking at the keyboard object for inspiration on how to code up my keyboard encoder, there are certainly many elements that can be reused.
    One part is used to wait for certain events such as clock_low, clock_high, clock_low and data_low etc etc. This code can do all of these things depending on the state of wcond. It seems you can enter the code block at wait_c0 or at wait, if you enter at wait you set wcond before hand.
    wait_c0                 mov     wcond,c0                '(wait until clock low)
    wait                    mov     y,tenms                 'set timeout to 10ms
    wloop                   movs    napshr,#18              'nap ~4us
                            call    #nap
    _c3                     test    cmask,ina       wc      'check required state(s)
    _d4                     test    dmask,ina       wz      'loop until got state(s) or timeout
    wcond   if_never        djnz    y,#wloop                '(replaced with c0/c1/c0d0/c1d1)
                            tjz     y,#reset                'if timeout, reset keyboard
    wait_ret
    wait_c0_ret             ret
    c0      if_c            djnz    y,#wloop                '(if_never replacements)
    c1      if_nc           djnz    y,#wloop
    c0d0    if_c_or_nz      djnz    y,#wloop
    c1d1    if_nc_or_z      djnz    y,#wloop
    The part I don't understand is that the mov command is used to set wcond when it is the source field of the djnz command that is being modified.
    Why isn't movs being used?
    Graham
    edited 2006-10-21 14:50
    Ah, I get it. Its the whole line at wcond that is being replaced.
    That's cool.
    I wish someone would wite something up on all this self modifying stuff so I can really get it. I'm very confused by what the labels on the lines actually are, is it like the "variable" c0 contains the command on that line or is it just an address or ......
    Graham
  • flapdoodle_dinghyflapdoodle_dinghy Posts: 17
    edited 2006-10-22 20:40
    I have been looking into the smaller keyboard idea too. Only nice one I saw was about $54 US from the UK.
    In searching I saw that USB to mini-DIN connectors work on "most" keyboards. I am wondering about that.
    I love the feel of the old Thinkpad keyboards made in 1995. Next year they were rubbery feeling and sticky. Since I have an old broke 755c I am planning to salvage the keyboard and interface it directly to a more modern keyboard encode. It will require tracing out all the line but I have done it before. It will give me a keyboard about 11" X 5"
    Thanks for sharing with us.
    Bill
    http://tech.groups.yahoo.com/group/parallax_propeller/
    edited 2006-10-22 21:15
    I was wondering about just using a standard keyboard encoder chip from a duff keyboard but unfortunately a lot of the keys on this one are combined, you have to press the function key to get page up for example.
    I'm making steady progress through th keyboard object, its taking me a while as I'm essentially learning how the propeller works at the same time as the code, I got really stuck on the look up table section until I realized that the adresses must all be to 32-bit blocks and the bytes in the table need to be extracted from those.
    If I can find a nice way of doing the mapping from pins to lookup on the encoder it could be very handy for things like laptop keyboards or even tiny keyboards from dead PDAs and the like, even my spell ckecker has a keyboard!
    Graham
  • Cliff L. BiffleCliff L. Biffle Posts: 206
    edited 2006-10-23 04:59
    You might also consider a PDA keyboard, like the Stowaways. They are (or were, back when I was looking) serial interfaced, with a simple byte-oriented protocol. I wrote a Linux driver for them some years ago, and it was quite straightforward -- the manufacturer even provides protocol docs and keymaps.
    You'd have to hack the connector and write a driver, but that's it.
  • Rob7Rob7 Posts: 275
    edited 2006-10-24 13:37
    Graham,
    Where can I purchase a mini keyboard like this ?
    I have searched with no great results.
    This would work great with my next project.
    Rob7
    edited 2006-10-24 16:14
    Its a keysonic nano, google should find it for you.
    Bear in mind using it relies on someone doing an encoder program or someone even dafter tackling a USB driver.
    Graham
    edited 2006-10-24 17:19
    This appears to be the same thing, but PS/2:
    http://www.keyboardco.com/keyboard_details.asp?PRODUCT=179
    edited 2006-10-24 19:37
    Thanks for the info.
    Rob7
    edited 2006-10-24 20:12
    flapdoodle_dinghy said...
    The keysonic is 218 X 103mm
    That one is 292 X 139
    So its quite a lot larger.
    Graham
    Graham Stabler said...
    Yours also appears to be a 2mm travel laptop-style keyboard, whereas this one looks to be full-travel.
    ...which for me, is a good thing. (I'm in the market for a PS/2 keyboard, having disposed of all of mine long since.)
