Keyboard encoder for the smallest keyboard
Graham Stabler
Some of you may remember that I made a housing for my demoboard, TV and keyboard to fit in a tiny flight case only to discover that the USB keyboard I had purchased was USB only and would not work with the adapters I had used with other keyboards. I discovered that there is sometimes a boot mode that allows the USB keyboard to work in a limited fashion in bios on a PC which could make interfacing easier however I couldn't get confirmation from manufacturer so I'm not going to risk the time and effort.
What I am left with is an array of switches going into a nice edge connector so I thought it might be a better bet to program a keyboard encoder to provide PS/2 from the keyboard.
I have found detailed info on the keycodes and the expected actions from the keyboard:
www.computer-engineering.org/ps2keyboard/
And full details on the PS/2 protocol:
www.computer-engineering.org/ps2protocol/
And of course the keyboard object that comes with the propeller has most of what is required, the keycodes, sending and receiving routines etc.
I'll have to work out the mappings between the edge connector and the keys but I'm confident it could be relatively straight forward and would do two things, provide me with the smallest keyboard I can find for any propeller apps I do and also provide some base code for anyone else who wants to make a custom keyboard for the propeller or even a PC.
If anyone has already done this or has a better idea please let me know.
Graham
The smallest keyboard in the west, out of its case and resting on the parallax micro keyboard. Its a Keysonic micro BTW, have seen these at very low prices.
Graham
One part is used to wait for certain events such as clock_low, clock_high, clock_low and data_low etc etc. This code can do all of these things depending on the state of wcond. It seems you can enter the code block at wait_c0 or at wait, if you enter at wait you set wcond before hand.
wait_c0 mov wcond,c0 '(wait until clock low) wait mov y,tenms 'set timeout to 10ms wloop movs napshr,#18 'nap ~4us call #nap _c3 test cmask,ina wc 'check required state(s) _d4 test dmask,ina wz 'loop until got state(s) or timeout wcond if_never djnz y,#wloop '(replaced with c0/c1/c0d0/c1d1) tjz y,#reset 'if timeout, reset keyboard wait_ret wait_c0_ret ret c0 if_c djnz y,#wloop '(if_never replacements) c1 if_nc djnz y,#wloop c0d0 if_c_or_nz djnz y,#wloop c1d1 if_nc_or_z djnz y,#wloopThe part I don't understand is that the mov command is used to set wcond when it is the source field of the djnz command that is being modified.
Why isn't movs being used?
Graham
That's cool.
I wish someone would wite something up on all this self modifying stuff so I can really get it. I'm very confused by what the labels on the lines actually are, is it like the "variable" c0 contains the command on that line or is it just an address or ......
Graham
In searching I saw that USB to mini-DIN connectors work on "most" keyboards. I am wondering about that.
I love the feel of the old Thinkpad keyboards made in 1995. Next year they were rubbery feeling and sticky. Since I have an old broke 755c I am planning to salvage the keyboard and interface it directly to a more modern keyboard encode. It will require tracing out all the line but I have done it before. It will give me a keyboard about 11" X 5"
Thanks for sharing with us.
Bill
http://tech.groups.yahoo.com/group/parallax_propeller/
I'm making steady progress through th keyboard object, its taking me a while as I'm essentially learning how the propeller works at the same time as the code, I got really stuck on the look up table section until I realized that the adresses must all be to 32-bit blocks and the bytes in the table need to be extracted from those.
If I can find a nice way of doing the mapping from pins to lookup on the encoder it could be very handy for things like laptop keyboards or even tiny keyboards from dead PDAs and the like, even my spell ckecker has a keyboard!
Graham
You'd have to hack the connector and write a driver, but that's it.
Where can I purchase a mini keyboard like this ?
I have searched with no great results.
This would work great with my next project.
Rob7
Bear in mind using it relies on someone doing an encoder program or someone even dafter tackling a USB driver.
Graham
http://www.keyboardco.com/keyboard_details.asp?PRODUCT=179
Rob7
The keysonic is 218 X 103mm
That one is 292 X 139
So its quite a lot larger.
Graham
Yours also appears to be a 2mm travel laptop-style keyboard, whereas this one looks to be full-travel.
...which for me, is a good thing. (I'm in the market for a PS/2 keyboard, having disposed of all of mine long since.)
