RealBasic to Propeller
T Chap
I am working on a RealBasic app that will send data to a Propeller. I am really confused on how to do this, maybe someone could understand what is the snag and clarify this stuff.
The data to be sent from RB to the Prop in one string:
MotorNumber1 byte
MotorNumber2 byte
MotorNumber3 byte
MotorNumber4 byte
Distance A long(possible word)
Distance B long "
Distance C long "
Distance D long "
ControlA 1-15 possibilities of numbers byte
ControlB 1-15 possibilities of numbers byte
Control 1 byte
Control 15 byte
Here is the motorMove method I was trying to make work, a scaled down version that is.
motorNumber As Integer, distance as integer
From what I can tell, the RB will send a binary byte like this, and the Stamp will receive it as a binary: &b00000000. However, I cannot find a way to set a variable to be a binary in RB, but I can just serial.write &b00000000 and it works. I get errors of mismatch when attempting to change the method to motormove as binarystream.
Now to the Propeller, it would really be helpful to find out how I am even going to deal with the data once I do get it in a format. In testing with the BS2p40, this seems to be a workable concept:
How to get a long value integer out of RB and reasembled in the Prop for use in the distance value? who knows
Right now the biggest question is to narrow down whether to use hex, bin, dec etc.
I am too tired to make a point.
MotorNumber1 byte
MotorNumber2 byte
MotorNumber3 byte
MotorNumber4 byte
Distance B long "
Distance C long "
Distance D long "
Control 1 byte
Control 15 byte
Dim msg As New MemoryBlock(4) msg.Byte(0) = motornumber 'works when looking for a number/text but not bin msg.Byte(1) = distance msg.Byte(2) =1000 msg.Byte(3) = &b11110000 ' test serial1.Write msg
'read the byte(11) if byte(0) = 0 then 'we are dealing with motor 1, therefore byte(1) = the distance to move motor 1 by the Props motorMove method byte(2) = the distance to move motor 1 by the Props motorMove method etc etc for all motors, all controls
Best,
Bill
Post Edited (originator99) : 10/22/2006 7:14:14 PM GMT
