Interfaceing the basic stamp with a pc.
MMISCOOL
I wood like to be able to send and retreive data from the basic stamp wile the stamp is conected to the computer via rs232 and was wonderin wether there wood be an ez was of using the debeugin and out comands with a peice of software on the computer. My favorite computere prograing language is liberty basic and I wood like for someone who has done something like this to posible help me with the code on the pc and stamp side. **excuse spelling errors
Post Edited By Moderator (Chris Savage (Parallax)) : 10/20/2006 4:36:18 AM GMT
The BASIC Stamp can be used to configure and read the interface. For example, the following code will create a slider StampPlot then use it to update a variable for playing a tone:
' {$STAMP BS2} ' {$PBASIC 2.5} PAUSE 1000 'allow connection to stablize Freq VAR Word DEBUG "!NEWP", CR, ' start a new plot "!O Clear",CR, ' clear any objects "!PPER 50,50",CR, ' reduce plot area to 50% by 50% "!O ohslider.freq=30,40",CR 'create a slider named Freq at 30 left, 40 up, 0- 100 for range DO DEBUG "!READ (freq)",CR ' request value of slider DEBUGIN DEC Freq ' accept returning value FREQOUT 8, 200, Freq * 50 ' sound tone on P8 LOOPStampPlot may be used for Free for home and educational use.
www.stampplot.com
If you want to create your own software, you simply need to access the serial port and accept and send values.
-Martin
Martin Hebel
Personal Links with plenty of BASIC Stamp info
StampPlot - Graphical Data Acquisition and Control
AppBee - XBee ZigBee / IEEE 802.15.4 Adapters & Devices
I have found software that can communicate with a Basic Stamp and store the data in an Excel or Acces file.
You can find the software on http://www.windmill.co.uk/
Has anywone has some experience with this software?
Greetings
