which format to draw schematic in
I would like to post my schematic. I can draw in autocad but I do not think I can cut and paste it into the forum and as such with the file as a attachment I do not think it will open for those that do not have autocad software.
·· I also have circuit maker and· electronics work bench (EWB), but I find these are slower to use.
·················· Thanks·· jonw
- Rick
jonw
A BMP (bitmap) would be just fine, but if you wanted to be more bandwidth frendly over the internet, convert the BMP's to JPG's
Beau Schwabe
IC Layout Engineer
Randy
http://usa.autodesk.com/adsk/servlet/index?siteID=123112&id=2404513&CMP=ILC-GN9219645015
To export an AutoCAD drawing (*.dwg) , while in AutoCAD, click on File - Export - and choose Save as type - Drawing Web Format (*.dwg) and name it.
Randy
·· I think more people would be likely to look at the schematics if they could easily open them.· To that end posting them as a GIF, JPG or, if need be a BMP would be best.· PDF works well too, especially since all of our online documentation is in PDF format, most people probably have the Reader installed.· Anything that requires a third party program that most people wouldn’t likely have installed would be a deterrent I would think.
Chris Savage
Parallax Tech Support
I just found out though I cant attach a file that is of a MIME x-PDF type (see attached .pNG file made with Snagit.
Snagit is a nice little program to capture your screen contents and the PNG format is pretty good for that. It's not free though.
Think outside the BOX!
- Rick
