10 amp BS2 controlled variable power supply (0 to 12V)
I need some help coming up with a 0 to 12 volt 10 amp variable power supply circuit that I can control with a BS2. Any ideas??
Thanks!
Boombox
Thanks!
Boombox
http://www.national.com/pf/LM/LM338.html
Look for the link to read the datasheet on-line, then scroll down to page 10, under "Typical Applications", the one I saw was rated to 15 Amps.
Instead of R8, a 2K ohm pot, you'd subsistute a digitally controlled pot.· This device recieves a digital input and adjusts it's resistance.·
Then connect the digital pot to the BS2.
There are some catches.· First, the lowest voltage out would be 1.2 volts, not zero as you asked for and a minimum load of 100 milliamps.· (Although a relay controlled by the BS2 could disconnect the load.)· Second, with these regulators, you need about 1.5 volts input above your·output, at 12 volts out, you'd need at least 13.5 volts in...at about 11 amps.· Finally, your going to need a large heatsink for the regulators and will probably need to use a fan too.
If this idea doesn't work for you, then just search for "10A adjustable power supplies", "schematics" and combinations of these words.· You should get a huge number of hits.· The digital pot idea subsitution idea should work in most·designs that use a variable resistor.
I hope this helped!
Post Edited (Desy2820) : 9/18/2006 2:08:13 AM GMT
If you want to control the power supply's voltage with a BasicStamp, a digitally controlled potentiometer would do the job most smoothly.
Take a look at the PDFs from the manufactures for the LM317 and LM350.
Alternatively, you can have digitally enabled selections by using a 2n2222 to turn on and off different set-ups of the regulator's control pin.
"If you want more fiber, eat the package.· Not enough?· Eat the manual."········
Thanks!
Boombox
·· Doubtful…It should work the same for small signals…What voltage are you putting into the AD5220?· I would have to double-check, but for some reason I believe that will only work with a 0-5V signal on the internal resistor terminals.· You can verify from the datasheet.· I hope this helps.
Chris Savage
Parallax Tech Support
N.B.·-- If the digital pot snuffs it, then will it go to max resistance or short?· If it goes short then the output voltage of the V.R.·will go to 0V (no problem), though if it goes to some high resistance then the output voltage will go to MAX.
·· I still think it would help everyone to help you if you posted a schematic or a link to one so we could see what you’re building or trying to build.· Is the first link·that was·posted where you're getting your idea from?
Chris Savage
Thanks in advance!!
Boombox
·· Okay, now that I am sure of what you’re doing, my advice would be to test my original theory by measuring the voltage between ground and the top of R8 with your standard POT.· See what the voltage reads all the way through the adjustments and let us know.
Chris Savage
·· That proves my initial theory, that you were trying to control too much voltage for the AD5220.· I don’t know if there is another digital pot that may work in this or not.·· The circuit may need to be revised to allow the functionality you’re looking for.
Chris Savage
·· Yes, you can use an Op-Amp, but it’s not as simple as just sticking the op-amp in there.· The circuit needs to be configured properly for the ADJ terminal to get the proper current/voltage characteristics.· I would Google for some circuits.· I know I have seen a few posted that use an Op-Amp to drive the ADJ terminal, but a few extra parts are required, such as resistors and a transistor.
Chris Savage
I am not an electronics expert so I·sometimes like reading the datasheet. (Yes, I know thats cheating) I have downloaded it from the link you provided and attached it. Read through it, specifically·the reference circuits on pages 9, 10, 11...
for example:-
An option·NI suggest is using a parallel binary input and 8 transistors. They also include a couple of examples of the use of opamps (though most of the opamps they specify are no longer available)
Herzogs suggestion of a negative voltage is also outlined here, specifically·-1.2V
Other suppliers have different circuits
About a year ago, I went the same·way you did but discovered that·both the digital pots I used only went to 5V or 5.5V. It's waiting on my bench for the serial digital option (0 to 24 in 255 steps or about 100mV a step).
Regards from Kwa Dukuza in Darkest Africa
John Bond
