Parallax, what is the possibility of a new propeller version? — Parallax Forums
Eric REric R Posts: 225
edited 2006-11-10 14:40 in Propeller 1
Will we ever see a propeller in a dip fashion including a voltage regulator, crystal, eeprom and programming standoff much like the BS2?
Sure seems possible.
    edited 2006-10-12 02:02
    Yes, the Propstick USB will be released shortly (dont ask for an exact date, but to give you a general indication of a timeframe I wrote a description for the website's product listing yesterday).
    Paul Baker
  • Eric REric R Posts: 225
    edited 2006-10-12 02:06
    Wow! Thanks, I look forward to it!
    Will this be along the same lines as the current prop stick or more integrated like the BS2?
  • ALIBEALIBE Posts: 299
    edited 2006-10-12 02:09
    Hi Paul,
    that is great to hear. What are the dimensions of such a board - looking forward to it.
    thanks in advance
    ALIBE - Artificial LIfe BEing. In search of building autonoumous land robot
    http://ALIBE.crosscity.com/
    http://fstop.crosscity.com/
    http://icar.crosscity.com/
    edited 2006-10-12 05:05
    It is the same dimensions as a BS2p40, we had to make it clear that it must not be placed in a BS2p40 socket since the pinouts and voltages are different. It is pin compatible with the original Propstick.
    Eric, what do you mean when you say integrated? It will be fully assembled using surface mount components and the QFN (leadless) package version of the Propeller.
    Paul Baker
    edited 2006-10-12 10:26
    That took care of my question. (Integrated meaning all parts on one board) This is what I am looking for and will wait for its release.
    edited 2006-10-12 13:30
    Paul, this is fantastic - exactly what I am looking for - Can't wait.
  • RsadeikaRsadeika Posts: 3,901
    edited 2006-10-12 14:11
    This sounds great, will their be a carrier board to go with this, or is this primarily for breadboard usage?
    Ray
    edited 2006-10-12 16:38
    Ray, its primarily for breadboard use.
    Paul Baker
    edited 2006-10-12 19:57
    Rsadeika said...
    If you want something for prototyping you may want to wait a little bit for the P8X32A-Q44 ProtoBoard...
    Don't visit my new website...
  • Kevin WoodKevin Wood Posts: 1,266
    edited 2006-10-13 19:28
    If it's possible from an engineering standpoint, it would be neat to have an interface board that would allow you plug the Propstick into a BS2p40 socket. Something like the way the PWM-Pal fits on a BS2.
    edited 2006-10-13 20:09
    It's a can of worms we are are not likely to open. There is a marginal chance something would be done, but not in the vein you are thinking.
    Paul Baker
  • RinksCustomsRinksCustoms Posts: 531
    edited 2006-10-15 04:14
    well we have landed a space probe on an asteroid, yes. . . . to answer your question, but the real question here would be if it's worth it to interface the prop to something designed for something 10 times slower...
    Definetly a E3 (Electronics Engineer Extrodinare!)
    "I laugh in the face of imposible,... not because i know it all, ... but because I don't know well enough!"
    edited 2006-10-15 05:34
    The benefit of having an interface isn't to connect the Propeller to a BS2p40; it's to be able to plug a Propeller into the 40-pin socket on the Professional Development Board.
  • MacGeek117MacGeek117 Posts: 747
    edited 2006-10-30 01:47
    You could possibly build your own-with the schematic and PCB making software around it wouldn't be too hard.
    RoboGeek
    "I reject your reality and subsitute my own!"
    Adam Savage, Mythbusters
    www.parallax.com
    www.goldmine-elec.com
    www.expresspcb.com
    www.startrek.com
    edited 2006-11-09 17:58
    just a friendly follow up on this. Any release dates for this prod?
    thanks
    "any small object, accidentally dropped, goes and hides behind a larger object."
    edited 2006-11-09 20:22
    No, Nagi we don't provide release dates, only general periods. We are getting all the ducks in line to make the product availible.
    Paul Baker
    Paul, thanks.
    I'm riding on the verse, "ask and it shall be given" [noparse]:)[/noparse]
    I'll bother again on this front in a week or so
