Stamp-->PC communication problem (Not Basic Stamp Editor) — Parallax Forums
FlyingFishFingerFlyingFishFinger Posts: 461
edited 2006-10-02 21:23 in General Discussion
Hi!
I need my Stamp to talk to Qbasic (eventually). The problem is, it won't even talk to a serial terminal. When I program it to send (whatever) to the PC, the debug window set to the appropriate COM port and baud mode sees the data, but neither the terminal program nor QBasic will see anything. I'm using Realterm and and a small·QBasic program·that just prints recieved data to the screen.
Is there anything stupid that I could have just·overlooked, or is there a bigger problem (This doesn't work on multiple PC's and different Stamps don't work either). I do close the Editor when trying to use Realterm or QB to avoid open port probs, but it doesn't make a difference.
Rafael
You've got to play the game.
You can't win.
You can't break even, except on a very cold day.
It doesn't get that cold.
~Laws of Thermodynamics~
    edited 2006-10-02 02:07
    I did some work ages ago before I started working for Parallax with this. You need to be in control of the DTR line in the serial cable.
    Check out this link under "StampII to QBASIC communication". hope this helps.
    http://webpages.charter.net/schwabelove/BasicStamp/Communication/Index.html
    Beau Schwabe
    IC Layout Engineer
    Post Edited (Beau Schwabe (Parallax)) : 10/2/2006 2:49:00 AM GMT
  • FlyingFishFingerFlyingFishFinger Posts: 461
    Nice. Thanks! That did the trick[noparse]:)[/noparse]
    Rafael
    You can't win.
