Parallax has release the USB version of the SX-Blitz
Bean
Check it out !!!
http://www.parallax.com/detail.asp?product_id=45170
Bean.
Cheap used 4-digit LED display with driver IC·www.hc4led.com
Low power SD Data Logger www.sddatalogger.com
SX-Video Display Modules www.sxvm.com
There are only two guaranteed ways to become weathy.
Spend less than you make.
Make more than you spend.
Bean.
James
No - that's outdated material and I'll see that it's removed. We are no longer supporting the ByteCraft C compiler.
wbahn - I can trade it out for - not a problem at all. Send me a PM and we'll make arrangements.
Since you guys have dealt with the development side of USB, I was wondering if you would be able to point me in the direction of where I might find an off-the-shelf chip to do USB 2.0 HS communications. I'm guessing you guys aren't using that, but you still may know where I can find such a critter.
Thanks.
Start this as a new thread in the "Sandbox". You'll get plenty of replies. Be clear in your needs, too. Are you looking for USB to serial or something different? As a new thread, in the right place, you'll get more replies.
