Video Question
Can the SX identify colors and shapes? For example could it tell the difference between a red triangle and a blue square?
Can it measure objects in a picutre? For example could it measure the square and the triangle to see how big they are?
If these can be done·does anyone have a link to code?
The SX is an 8 bit microcontroller.
It only does what you tell it to, and you have to be very specific.
It cannot recognize anything, any more than you could plunk a pentium CPU on top of your algebra book and expect it to do your homework.
If I were setting out to solve the problem of cognitive machine, vision the SX chip would not be my first choice of computing platforms.
I suggest you start here:
www.transit-port.net/AI.CogSci.Robotics/robotics.html
Good luck, you will need it!
I wonder if this wire is hot...
and here's a version that's specifically designed to work with the BS2 www.parallax.com/detail.asp?product_id=30051
