HC4LED Demo with SX/B 1.50
Bean
Okay, here is what everyone with the HC4LED modules has been waiting for...
This program has a routine named "DisplayValue" that will display a word value from -999 to 9999 on the HC4LED display. It will also blank the leading zeros (so 12 doesn't display as 0012).
Look this over even if you don't have the HC4LED modules because it's a good example of what can be done in SX/B 1.50.
Bean.
Cheap 4-digit LED display with driver IC·www.hc4led.com
Low power SD Data Logger www.sddatalogger.com
"I'm a man, but I can change, if I have to, I guess" The Red Green Show
Bean.
It's Only A Stupid Question If You Have Not Googled It First!!
