just to be safe i would get a 5 volt regulator the LM7805 from Radioshack and run the supply through that first. if anything DOES fry i want it to be the 1.79 Regulator instead of my 80 dollar Boe
-Learn somthing about everything, and Everthing about somthing-
The problem with computer power supplies is that many are extremely noisy.· This can result in some circuits and/or programs exhibiting weird symptoms which you may not attribute to the power supply, but could very well be related.· This can cause countless hours of hair pulling.·
▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔ Chris Savage Parallax Tech Support
I wouldn't connect that if I were you...
Vive Le Tour!
July 1 - July 23
Chris Savage
