Running BOE off of PC power supply — Parallax Forums
nikanika Posts: 11
edited 2006-09-21 20:09 in BASIC Stamp
What are your thoughts on running the BOE off of a PC power supply molex connector(12v). Can the onboard voltage regulator handle this? Thanks, nik
  • aalegadoaalegado Posts: 66
    edited 2006-09-21 04:29
    That's not a problem...it's within specification. I run my PDB and BOE off of a ATX power supply's 12V rail.
    I wouldn't connect that if I were you...
    Vive Le Tour!
    July 1 - July 23
  • willthiswork89willthiswork89 Posts: 359
    edited 2006-09-21 11:19
    just to be safe i would get a 5 volt regulator the LM7805 from Radioshack and run the supply through that first. if anything DOES fry i want it to be the 1.79 Regulator instead of my 80 dollar Boe
    -Learn somthing about everything, and Everthing about somthing-
    edited 2006-09-21 14:26
    The BOE already HAS an 'on-board' voltage regulator, the 3840-5. It's hard to fry, and simple to replace if you know how to solder.
    The problem with computer power supplies is that many are extremely noisy.· This can result in some circuits and/or programs exhibiting weird symptoms which you may not attribute to the power supply, but could very well be related.· This can cause countless hours of hair pulling.·
