Show me the WAY! Question on LCD — Parallax Forums
DiablodeMorteDiablodeMorte Posts: 238
edited 2006-09-20 20:58 in General Discussion
I found this LCD(1cm by 1cm(yea, it's small)). I have absolutly no background on how LCD's are controlled or how to control them. Anyway. I was wondering if one of you could help me with the control of this LCD I found. I drew up a schematic(Not really a schematic but a crappy picture). Could one of yall "show me the way"?
With the schematic:
THe lcd has 15 wires coming from it
The board the LCD is connected to, does not contain electronics. It just translated the 15 wires into two pads with 1 set of seven wires and 1 set of 8 wires. The LED + and LED - pads are not connected.
Any suggestions?
  • BeanBean Posts: 8,129
    edited 2006-09-19 12:27
    Do you have a datasheet ? Or a link to the datasheet ? Or a model # ?
    With more info, we're pretty much just guessing.
    I suspect that the LCD is "bare" (does not have the drive circuit). That means you will have to supply an AC voltage to drive the LCD segments.
    Bean.
    Cheap used 4-digit LED display with driver IC·www.hc4led.com
    Low power SD Data Logger www.sddatalogger.com
    SX-Video Display Modules www.sxvm.com
    There are only two guaranteed ways to become weathy.
    Spend less than you make.
    Make more than you spend.
  • DiablodeMorteDiablodeMorte Posts: 238
    edited 2006-09-19 20:15
    How would i check if it was "bare"? I can't find a schematic on the internet. How would i test the lcd with out damaging it?(I just killed my car's dash by shorting it. I would like to not do the same with the lcd)
  • SuperwormsSuperworms Posts: 118
    it would also help in we could see the lcd
    Equipped with his 5 senses, man explores the world around and calls his adventure science
    -Edwin Hubble
