Show me the WAY! Question on LCD
I found this LCD(1cm by 1cm(yea, it's small)). I have absolutly no background on how LCD's are controlled or how to control them. Anyway. I was wondering if one of you could help me with the control of this LCD I found. I drew up a schematic(Not really a schematic but a crappy picture). Could one of yall "show me the way"?
With the schematic:
THe lcd has 15 wires coming from it
The board the LCD is connected to, does not contain electronics. It just translated the 15 wires into two pads with 1 set of seven wires and 1 set of 8 wires. The LED + and LED - pads are not connected.
Any suggestions?
With the schematic:
Any suggestions?
With more info, we're pretty much just guessing.
I suspect that the LCD is "bare" (does not have the drive circuit). That means you will have to supply an AC voltage to drive the LCD segments.
Bean.
There are only two guaranteed ways to become weathy.
Spend less than you make.
Make more than you spend.
Equipped with his 5 senses, man explores the world around and calls his adventure science
-Edwin Hubble
