Interfacing the AD3370 to Bs2
·Dear Forum,
·I am confuse in connecting the AD7730 to the BS2.
·Do we need a clock or timing to calculate the weight.
·Could you please let me know·how to connect the AD7730 to the Bs2.
·I figured·how to connect the thin bridge laod cell to the AD7730 and already have·a sample code from·
·mohammed.
·My project is a toy which measures·a weight and shows it on a lcd screen.
·Any advice or recomendations will be really appreciated.
·Aaron··
·mohammed.
·Aaron··
(SCLK) pin1
pin12 (P7)
(DIN) pin22
pin13 (P8)
(DOUT) pin21
pin14 (P9)
(RDY) pin20
pin15 (P10)
To calculate the weight for 5kg load cell with 2mV/V o/p:
Input range = 10
16 bit mode
5V excitation voltage
weight = code**5000 'weight in grams
For full-scale calibration use your software to correct the value.
