Hey did everyone see this! Parallax GPS receiver modules.
Check it out... http://www.parallax.com/detail.asp?product_id=28146
Bean.
Cheap used 4-digit LED display with driver IC·www.hc4led.com
Low power SD Data Logger www.sddatalogger.com
SX-Video Display Modules www.sxvm.com
There are only two guaranteed ways to become weathy.
Spend less than you make.
Make more than you spend.
Bean.
It's Only A Stupid Question If You Have Not Googled It First!!
Post Edited (altitudeap) : 9/16/2006 3:25:42 AM GMT
Ken
How easy is it to re-program the SX on these ? That is what I want to do with them, but I don't see any SX-Key header in the pictures.
Bean.
I have one thing to ask and that is when you run the memory map it shows 95% full
Would you able to put the Output to a LCD Display or would you have to use another BS2 to use·a LCD Display for the ouput of the
Will there a Demo that will show how to do this with two BS2 one for the GPS receiver module and one for a LCD Display····· Any··
Thanks for any help in this matter
Sam
The demo program shows how to use all of the features, but you'll have to pick those you really want to use --·you can't have it all·(or... get a BS2p.)
·· There are pads on the board for attaching an SX-Key/Blitz with a 4-pin header in it (The Key/Blitz) or you could tack the header onto the pads/holes.
Chris Savage
Parallax Tech Support
·· I assume the 95% full you refer to the BASIC Stamp with the demo code loaded?· Remember, this code (like the DS1302 Demo Code) is an example of how to access all of the data from the GPS Receiver.· With the menu, debug statements, etc. it will be larger than your own program that may make use of this device.· As for an LCD, yes, you could send the data to a Parallax Serial LCD, but you would have to reformat the output and configure which data you want since the LCD won't be able to display as much as the PC Screen using DEBUG.· There won't be a demo for 2 BS2 sicne that is not necessary.· Take care.
Chris Savage
Thanks for your reply that help alot
Sam
But why is the baud rate at 4800 and not at 9600 so to be able to connect at the serial port of the PC without having to mod the SX code...
-Rule your Destiny-
--Be Good. Be Bad. Be Provas--
The hellinic (Greek) robots portal: Greekbotics
Many Projects and Schematics by the users·and also robotic news
(Translate using babelfish)
It's hard explaining to the mrs. who Parallax is! haha And why do I have all of their boxes on my shelves...and when am I going to build something with all their parts!
Sigh....haha
Steve
"Inside each and every one of us is our one, true authentic swing. Something we was born with. Something that's ours and ours alone. Something that can't be learned... something that's got to be remembered."
· I heard a rumor that this also has some extra "hacker" pins/pads on it too.
· Can you confirm or deny·that ?
Bean.
Post Edited (Bean (Hitt Consulting)) : 9/18/2006 5:40:33 PM GMT
-Rusty-
Rusty Haddock = KD4WLZ = rusty@fe2o3.lonestar.org
**Out yonder in the Van Alstyne (TX) Metropolitan Area**
Microsoft is to software what McDonalds is to gourmet cooking
··· The extra pads on the back are test points which connect to unused I/O pins on the SX20.· Advanced Users could take advantage of these (8) pads to gain access to these I/O pins without having to solder onto the pins of the SSOP package.· Attached is a schematic for the module which should be on our website soon as well.· I hope this helps.· Take care.
Chris Savage
Thanks. That does help. I LOVE to see hacker friendly modules.
Now I can't wait to get mine in the mail...
Bean.
