Battery Help needed
Attached are two pics of some NiMH batteries I am using temporarily till I get some info. I need a single really low profile battery, appox 1.85" x 2.75" as shown(when combining 5 smaller batteries).
It seems the newest and best stuff these days is Lithium ion. Preferrably, a smart battery with it's own management, just plug in the charger and not worry about it. I already put a 2.5mm dc jack pinout on the boards, although they could be 2.1mm just as well, I also just set up the boards to run two wires straight to the battery(s), multed to the pcb(3.3reg) and the dc jack. There is no management on the boards. I got these batteries shown which are 1.2v 1400aH at all electronics, and will solder them together to get 6v for temp use, but need a better solution that is very reliable and headache proof. Google has 90000 possibilities, any body got a suggestions?
PS wire leads are preferred to attach to the header pins on the pcb.
http://www.batteryspace.com/
James
Looking at the photo you submitted, I do not see any solder tabs on the batteries.· DO NOT solder directly to the batteries.· There is a potential for physical damage if the battery gets too hot.· Suggest you stick with commercially available battery packs.·
Bill
"If you want more fiber, eat the package.· Not enough?· Eat the manual."········
http://www.sparkfun.com har a neat little one-cell Li-ion charger for about $15, and matching Li-ion cells of 100mA(Stamp-sized and so light that you wouldn't believe it, for $6), 860mA($7) and 2000mA($13)
Their two-cell charger is $42, though.
(I like the one-cell charger as it's a small PCB, the size of a stamp, and easily built into any project)
Don't visit my new website...
I was looking for something at or above 1000, so these will work great. Thanks for the hookup. The Maxs1555 board is interesting, I can probably fit it in there as well if I lose the jacks, or maybe just build my own 1555 circuit.
OT I just got in a tube of LM2937ET-3.3 3.3v regulators. No matter what I put into the pin one, with GND at pin 2, the output is always Vin - .5v . I haven't tried anything over 12 for Vin. I tried every one in the tube, I tried two different supplies, two diferent breadboards. I am thinking the must have been mismarked, and are really 12 or 15 regulators.
[noparse][[/noparse]See pic attached.]
The same way as the schematic you posted. 7805's, 7812's, and others are usually all the same pin out, these are obviously mismarked since the whole batch will not produce 3.3v. I haven't tried putting in 24 to see where it really starts regulating. I have hooked up a lot of regulators, this is a first.
According to the Sparkfun site, they are usng the MAX1555 to charge those Lipo batteries. I will get some of the ic's in and make a tiny board to fit inside the remote.
I have tried 5 volts, 9, 24, 5 different LM2937ET-3.3 regulators, all produce approx 90% Vin at the output. Plug in a 7805 in the same holes = 5 volts. I am not using any thing else attached while testing, just inout, GND, and a meter.
Post Edited (originator99) : 9/17/2006 12:07:40 AM GMT
2C continuous discharge
Excellent long-term self-discharge rates (<8% per month)
1 * CR123 primary lithium (LiMnO2), 3 volts, 1500 mAh, 17 grams
2*AA Alkaline, 3 volts, 2800 mAh, 46 grams
2*AAA Alkaline, 3 volts, 1200 mAh, 22 grams
3*AA NiMH, AA, 3.6 volts, 1800 mAh, 84 grams
1*AA Lithium-Ion (Batteryspace) 3.6 volts 750mAh, 20 grams
Primary EL123 lithium (Li/MnO2, 3 volts) cells are becoming more economical from online suppliers because of their popularity in devices like emergency flashlights, and they are really great in terms of energy per unit weight, long long shelf life, and good performance at extremes of temperature. I can understand well though that you want to use a rechargeable battery for this project. Pb-acid batteries are easy to recharge, but they are terrible on the energy per unit weight spec. I'll be interested to hear how your experiments with the MAX1555 turn out.
The LM2937 is an old regulator design and it is not very efficient. Note that the data sheet specifies the output voltage with a load of at least 5 milliamps, and the output capactor of at least 10uF is required. These things can do strange stuff if they don't have the output capacitor.
Tracy Allen
www.emesystems.com
As far as the battery, originally I wanted to use a 9v, but it is too bulky and would add over .25" to the device. I then settled on .25" as the max thickness, and the iPod style seemed like a natural fit. There is a trade off for everything I suppose. I really didnt want the customer to have to pull the box a part to change batteries, nor did I want it to die once a month. At first I thought to use an external smart charger, but that has it drawback too. If someone loses the charger and uses a regular unregulated wall wart, then I will get complaints and headaches.
As far as the regulator, it is not in the circuit unless a button is pressed, and the boot up time for every press doesn't seem noticable. The Xbee Pro's modules came in today, pretty cool gadgets. Just like wire right out of the box, I haven't tested distance yet.
Thanks for the help.
Post Edited (originator99) : 9/17/2006 2:44:51 AM GMT
