Bored with new boe-bot need new project
about 2 weeks ago i bought the boe-bot and its very cool, ive read the whole book and done all the projects in it and i got bored cause i ran out of things to do
recintly i bought about 20 different LED's and made some pretty cool light shows then got bored with that
well im wondering if anyone can tell me some idea or some projects that i can do
What's your interest?
-Learn somthing about everything, and Everthing about somthing-
you think i could make the boe-boe run on that?
LEFT
RIGHT
BACK
FRONT
NEGATIVE
POSITIVE
basically if left is triggered it grounds to 0, else its a one simply put you can decide whats being pressed by checking these for values.
Attached is the code that i used to do this.. im still a little messy so ignore that haha
that sounds easier
then ill juice it up and make it cool
good start at BlueBell
http://www.bluebelldesign.com/Subsumption_Engine.htm
Making the Boe-Bot wonder and avoid objects was not as easy as I thought it might be. It might be a sinch for you...
http://www.schursastrophotography.com/robotics/subsumption1.html
You can take a look at some mini-projects posted in the Stamps in Class Forum (the Boe-Bot full kit is a Stamps in Class product so you can find more information there or in the Robotics forum).
http://forums.parallax.com/showthread.php?p=560570
There is also a book that expands the use of the Boe-Bot with the hardware you already own. You only need a programmable remote control. You can download or buy the book from this link:
http://www.parallax.com/detail.asp?product_id=28139
Ready to start a competition with some friends? You can find the some more information here:
http://forums.parallax.com/showthread.php?p=591070
This should keep you busy for a while.·· ;-)
Aristides Alvarez
Education and Technical Support Manager
