Read Range of the RFID
Im planning a little project with this RFID reader but before i buy it i need to make sure where im putting it it will be able to read, i wanted to hide it in my car under neath the dash padding but now reading 5cm, im worried it wont be able to read through it. can someone answer what card will read best farthest?
-Learn somthing about everything, and Everthing about somthing-
Post Edited (willthiswork89) : 9/9/2006 6:45:28 PM GMT
I think what·your are tring to do will work but you will have keep the reader will have to be as close to the dash as you can get it
I·put the reader in a plastic box and it works real good
·But i notice that if you put to much space from box lid to the reader it would not work now
if i mounted the reader as close to lid it works but you have to put card to the box lid then it works good
Here is the Post where i did·this·
http://forums.parallax.com/showthread.php?p=571682
You look at this post also where put the reader behind a sheet of·plastic
http://forums.parallax.com/showthread.php?p=595469
I hope this help you with what you are tring to do
Sam
Post Edited (sam_sam_sam) : 9/9/2006 7:31:54 PM GMT
·· If the reader is behind a metal panel it won't work.· The metal will act as a sheild for the RF Signals.· Plastic should work.· Take care.
Chris Savage
Parallax Tech Support
You might want to try a search engine next time!
http://www.sokymat.com/
Just remember BOTH transmitter and receiver MUST be compatible with one another.
Bruce Bates
<!--StartFragment -->
I Went there and its impossible to find somwhere to buy these things, all i found was Available on requent by: Titan and i dunno what to do or what type to get, i did buy the little round tag but ide like to get one that will go on my keychain im not sure on the readers capabilitys and compatibility with any of this. i just seen in the N&V that he had the Keyfob
http://www.cyntag.com/index.htm
Chris Savage
Dave
Dave Andreae
Tech Support
dandreae@parallax.com
Http://www.parallax.com
