Sony SIRCS Decoding
I am curous to know why, when you change the device· OSCXT2 to OSC4MHZ, the program does not run as expected, the IR part does not work. Is their a problem with the pulsin command when it is run at the OSC4MHZ setting? It seems to me that I did not have this problem before, although I could be mistaken. I am using the example program that is listed in the SX/B example projects.
Ray
Ray
· The internal oscillator is not accurate enough for timing such things. SERIN and SEROUT won't work correctly either when using the internal oscillator. It is about +/- 8% so it can vary quite a bit. An even if you use IRC_CAL it it very unreliable.
Bean.
Cheap 4-digit LED display with driver IC·www.hc4led.com
Low power SD Data Logger www.sddatalogger.com
"You're braver than you believe, stronger than you seem, and smarter than you think" Christopher Robin to Pooh
Ray
I'll have to check, but I think if you are DEBUGGING, then the SX-Key will provide the clock "even if you specify OSC4MHZ", but if you just RUN from the IDE, then I think the internal oscillator is used. If I get time today I will verify that.
Bean.
I have confirmed with a frequency counter, that when you are debugging, the SX-Key generates the clock, even if you specify OSC4MHZ on the device line.
Bean.
