Small Plastic Box
Folks -
I have a small piece of PC test equipment that needs a "home". I'd like to put it in a small, flat box with some sort of snap-lock. Plastic is okay IF I have additional room (over and above the basic dimensions) for a piece of anti-static foam.
Essentially what I'm thinking about is like a "tin" of aspirin, but a bit larger. Clear would be great, but I can always label it if need be.
Here are the overall dimensions:
3.5" wide X 2.5" high X .50" deep
TIA
Bruce Bates
TIA
Bruce Bates
3.6 x 2.3 x 0.75in
Funny, I thought I tried an Altoids tin, but it was an older one. may have to buy some new and check it out.
Thanks guys!
Bruce
<!--StartFragment -->
Jeff T.
Would that be acceptible.
I am wondering why the antistatic foam?
I buy them in the Parts Box area of my local electronics supplier. It has real hinges and a snap lock.
"If you want more fiber, eat the package.· Not enough?· Eat the manual."········
Yup, that would do it. The anti-static foam is because the device has a number of CMOS parts on it. The box is just for storage, when I'm not using it.
Bruce Bates
As I recall they are $50NT or about $1.80USD.
It was my impression that the antistatic foam was needed for loose parts.
And once in a circuit, the static hazard is supposed to be significantly reduced.
I have my Propeller just mounted to the lid with double adhesive tape.
When I open it, I have access to all the plugs, etc.
When it is closed, it doesn't rattle around.
Check Flambeau and Plano, too. I'm a real plastic box nut.
Got 'em all over my shop!
Ken
Thanks so much, I'll check them out.
Bruce Bates
