Small Plastic Box — Parallax Forums
Small Plastic Box
Bruce BatesBruce Bates Posts: 3,045
edited 2006-08-29 01:03 in General Discussion
Folks -
I have a small piece of PC test equipment that needs a "home". I'd like to put it in a small, flat box with some sort of snap-lock. Plastic is okay IF I have additional room (over and above the basic dimensions) for a piece of anti-static foam.
Essentially what I'm thinking about is like a "tin" of aspirin, but a bit larger. Clear would be great, but I can always label it if need be.
Here are the overall dimensions:
3.5" wide X 2.5" high X .50" deep
TIA
Bruce Bates
    edited 2006-08-27 16:06
    If metal is ok, there's a line of caffeinated mints, brand name Penguin, that come in a nice snap tin about 3 5/8 x 2 3/8 x 3/4 inch. The caffeine would help you stay up to finish the project.
    edited 2006-08-27 16:14
    ...or Altoids (they're metal boxed, too.)
    3.6 x 2.3 x 0.75in
    edited 2006-08-27 16:42
    PJ -
    Funny, I thought I tried an Altoids tin, but it was an older one. may have to buy some new and check it out.
    Thanks guys!
    Bruce
    <!--StartFragment -->
  • UnsoundcodeUnsoundcode Posts: 1,532
    edited 2006-08-27 17:12
    An old VHSC tape box makes a nice "project box"·unfortunately the height is only 2.375. (3.75 x 2.375 x .25). They are especially nice if you like to admire your artwork occasionally :-)
    Jeff T.
    edited 2006-08-27 18:23
    I am using a 3 1/2" x 4 1/2" x 3/4" clear plastic [noparse][[/noparse]polyethyilene] box for my Propeller Demo board.
    Would that be acceptible.
    I am wondering why the antistatic foam?
    I buy them in the Parts Box area of my local electronics supplier. It has real hinges and a snap lock.
    "If you want more fiber, eat the package.· Not enough?· Eat the manual."········
    ···················· Tropical regards,····· G. Herzog [noparse][[/noparse]·黃鶴 ]·in Taiwan
    edited 2006-08-27 18:37
    Hi George -
    Yup, that would do it. The anti-static foam is because the device has a number of CMOS parts on it. The box is just for storage, when I'm not using it.
    Bruce Bates
    edited 2006-08-28 21:25
    So... do you want to come to Taiwan or ....... ?
    As I recall they are $50NT or about $1.80USD.
    It was my impression that the antistatic foam was needed for loose parts.
    And once in a circuit, the static hazard is supposed to be significantly reduced.
    I have my Propeller just mounted to the lid with double adhesive tape.
    When I open it, I have access to all the plugs, etc.
    When it is closed, it doesn't rattle around.
    edited 2006-08-28 21:27
    Bruce,
    Check Flambeau and Plano, too. I'm a real plastic box nut.
    Got 'em all over my shop!
    Ken
    Ken -
    Thanks so much, I'll check them out.
    Bruce Bates
