How to connect BS2 to H-Bridge motor
Hi all
I have problem how to connect BS2 to H-Bridge motor.
Here I attached the schematic diagram of the H-Bridge.
Pls help.
Pls help.
I'm not sure I see your problem. Here's the way I read the schematic:
Pin 7 - V-
Pin 6 - V+
Pin 5 - unconnected
Pin 4 - control lines for
Pin 3 - motor # 1
Pin 2 - control lines for
Pin 1 - motor # 2
Motor Control Pins
0 0 = motor off
0 1 = motor FWD
1 0 = motor REV
1 1 = DO NOT USE!
What's more to say?
Bruce Bates
<!--StartFragment -->
1) R29 and R32 seem to be swapped with each other as well as R31 and R35
2) I would remove C15 and C16 and replace them with bridge rectifiers.
For M1, connect each AC terminal "~" to the motor, then connect the "+"
to the connector pin 6 and the "-" to the connector pin 7. Do this again
for M2.
Beau Schwabe
IC Layout Engineer
Thanks to·Bruce & Beau· for your reply.
Actually I'am giving wrong info. What I want to do is connecting the circuit to BOE.
How to connect SK1 to the BOE. I want to use external power supply to the circuit. not from the BOE.
Sorry for that.
For the Bridge Rectifiers can u draw the schematic diagram how to replace the C15 & C16.
I'am only beginners so i can't understand trough words.
That's what you should do anyway. What you need to do though is connect
the grounds together.
Basically you would have 2 of the circuits below. And apply the truth table
from the BOE. Select the I/O pins that you will want to use for the output.
You will need 4 total to do this.
BS2 EXAMPLE CODE
' {$STAMP BS2} ' {$PBASIC 2.5} 'INITIALIZE Variables and Constants INP_A1 CON 0 'IO INP_A MOTOR1 ... Range 0 to 15 INP_B1 CON 1 'IO INP_B MOTOR1 ... Range 0 to 15 INP_A2 CON 2 'IO INP_A MOTOR2 ... Range 0 to 15 INP_B2 CON 3 'IO INP_B MOTOR2 ... Range 0 to 15 IO_MASK VAR W0 IO_MASK = 1<<INP_A1 + 1<<INP_B1 + 1<<INP_A2 + 1<<INP_B2 LOW INP_A1 'Preset MOTOR outputs LOW LOW INP_B1 LOW INP_A2 LOW INP_B2 DIRS = IO_MASK MainLoop: HIGH INP_A1 'MOTOR1 forward for 5 seconds PAUSE 5000 LOW INP_A1 'turn MOTOR1 OFF HIGH INP_B1 'MOTOR1 reverse for 5 seconds PAUSE 5000 LOW INP_B1 'turn MOTOR1 OFF HIGH INP_A2 'MOTOR2 forward for 5 seconds PAUSE 5000 LOW INP_A2 'turn MOTOR2 OFF HIGH INP_B2 'MOTOR2 reverse for 5 seconds PAUSE 5000 LOW INP_B2 'turn MOTOR2 OFF GOTO MainLoop▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔
Beau Schwabe
IC Layout Engineer
Post Edited (Beau Schwabe (Parallax)) : 8/26/2006 5:45:35 AM GMT
I will use the schemstic that u provide.
One more question. Do I need the rectifier if my external source form DC?
Regards
Azmax100
Beau Schwabe
IC Layout Engineer
smoke-able and smoke-less.
The reason Bruce Bates has DO NOT USE the 11 code is that it will damage at least the first·H-bridge.
I am all for building a couple of individual component H-bridges to learn about it. But it is hard to beat the off-the-shelf solutons for durable control. Often the best reason for getting an H-bridge IC or a package [noparse][[/noparse]like the HB-25] is that you have that additional protecton circuitry.
"If you want more fiber, eat the package.· Not enough?· Eat the manual."········
