Parallax Thermocouple Kit with SX28 Tech Board
Bean
Here is some code to use the Parallax Thermcouple Kit (#28022) with the SX28 tech board.
It uses the Parallax serial LCD to display the thermocouple temperature.
Parallax, feel free to include this as a download for the Thermocouple kit. (You'll probably want just the SXB code though).
[noparse][[/noparse]edit] Aug 18, 2006 12:45PM; I added some comments to the spreadsheet and SXB file to explain how I calculated the·thermocouple temperature with such a small data table.
Bean.
Cheap 4-digit LED display with driver IC·www.hc4led.com
Low power SD Data Logger www.sddatalogger.com
"You're braver than you believe, stronger than you seem, and smarter than you think" Christopher Robin to Pooh
Post Edited (Bean (Hitt Consulting)) : 8/18/2006 4:51:11 PM GMT
Bean.
Chris Savage
Parallax Tech Support
csavage@parallax.com
I just uploaded a new version. The SXB is the same (just a couple comments added). The speadsheet now has comments explaining how I calculate the thermocouple temperature with very little data tables. I'm sure the same technique could be used on the stamps too.
Bean.
·· I have the updated copy.· Thanks.
Chris Savage
