IEEE 488 bus general purpose interface bus
Hello,
I was wandering if someone as already implemented this bus. If not I will try to implement it for the javalin. Please let me know.
Kind regards,
Maarten Storm
Kind regards,
Maarten Storm
I found a good description here:
http://www.optics.arizona.edu/opti360/Week%2013.pdf
(just the first 14 pages that end with·a code example, the rest is about usb).
As the IEEE 488 requires 16 I/O lines,
are you planning on dedicating an entire javelin to this bus?
regards peter
Post Edited (Peter Verkaik) : 8/14/2006 8:18:00 PM GMT
http://www.viceteam.org/plain/serial.txt
regards peter
monitors a serial IEC bus (program IEC-CRO)
via a printer port. Might be useful to you.
http://www.64hdd.com/projects/c64-proj4.html
regards peter
