Need Precise Electronic Compass
I'm working on an application that requires a compass. I need to read within 0.5 degrees. The output needs to be linear and repeatable. By repeatable I mean, if I sweep 30 degrees and then return to my starting point, the result will be read as my original heading +/- 0.5 degrees.
The electronic units I've been looking at don't appear to meet these requirements. I'm wondering about mounting a supermagnet on the end of a 10 bit encoder. If encoder friction is low enough the super magnet may follow magnetic North.
I can design my application so the compass apparatus is always parallel to the ground, so tilt isn't a problem.
I can also live with an absolute error or 1 or 2 degrees, provided the readings are consistently linear, or an algorithm can be created to adjust for the error to a final value of +/-0.5 degrees.
The apparatus can be placed to eliminate the impact of ferrous objects. But it needs to be moveable, typically within +/- one degree of longitude or latitude.
Any ideas out there?
http://www.ssec.honeywell.com/magnetic/datasheets/HMR3500.pdf
- Stephen
http://shop.ssec.honeywell.com/shopdisplayproducts.asp?id=6&subcat=12&cat=HMR3xxx+-+Products+and+Accessories
John R.
8 + 8 = 10
A compass is a fundamental tool for them, but the tool has its limits. Anything ferrous that is nearby can throw them off by quite a bit. For example, if you have a roving robot and it passes a metal table leg, you are not going to get a good reading.
When hiking in the woods, metal buttons on a Levi jacket can make for lost woodsman. Or a metal watchband. A good woodsman will set the compass down on a rock and look at it from a bit of distance.
So think about it. Nickel is ferrous [noparse][[/noparse]as in NmH batteries], and their case is Iron [noparse][[/noparse]also ferrous].
If you look at ships and sail boats, even they have compensation for the ferrous metals around them.
That seems to be 'the way of the compass'.
"If you want more fiber, eat the package.· Not enough?· Eat the manual."········
The comment about moving a degree of latitude or longitude was in recognition that electronic earth field sensors require new calibration with significant longitude changes.
www.robot-electronics.co.uk/
or maybe in the states at:
www.acroname.com/index.html
Should be around $50-$60
The software side is easy, here is a full workout of what the unit does:
Regards
Tim
