Need Precise Electronic Compass — Parallax Forums
bobledouxbobledoux Posts: 187
edited 2006-08-14 15:14 in General Discussion
I'm working on an application that requires a compass. I need to read within 0.5 degrees. The output needs to be linear and repeatable. By repeatable I mean, if I sweep 30 degrees and then return to my starting point, the result will be read as my original heading +/- 0.5 degrees.
The electronic units I've been looking at don't appear to meet these requirements. I'm wondering about mounting a supermagnet on the end of a 10 bit encoder. If encoder friction is low enough the super magnet may follow magnetic North.
I can design my application so the compass apparatus is always parallel to the ground, so tilt isn't a problem.
I can also live with an absolute error or 1 or 2 degrees, provided the readings are consistently linear, or an algorithm can be created to adjust for the error to a final value of +/-0.5 degrees.
The apparatus can be placed to eliminate the impact of ferrous objects. But it needs to be moveable, typically within +/- one degree of longitude or latitude.
Any ideas out there?
    edited 2006-08-11 22:09
    How about this?
    http://www.ssec.honeywell.com/magnetic/datasheets/HMR3500.pdf
    - Stephen
  • John R.John R. Posts: 1,376
    edited 2006-08-12 17:18
    From references on the same site, see also the 3100 (at only $100.00 vs. $675.00)
    http://shop.ssec.honeywell.com/shopdisplayproducts.asp?id=6&subcat=12&cat=HMR3xxx+-+Products+and+Accessories
    John R.
    8 + 8 = 10
    edited 2006-08-12 20:27
    Having lived in Oregon for 15 years, I learned a lot from woodsmen. In particular, I used a compass to hike a straight line of 15 miles for timber cruising [noparse][[/noparse]inventorying the trees in a forest].
    A compass is a fundamental tool for them, but the tool has its limits. Anything ferrous that is nearby can throw them off by quite a bit. For example, if you have a roving robot and it passes a metal table leg, you are not going to get a good reading.
    When hiking in the woods, metal buttons on a Levi jacket can make for lost woodsman. Or a metal watchband. A good woodsman will set the compass down on a rock and look at it from a bit of distance.
    So think about it. Nickel is ferrous [noparse][[/noparse]as in NmH batteries], and their case is Iron [noparse][[/noparse]also ferrous].
    If you look at ships and sail boats, even they have compensation for the ferrous metals around them.
    That seems to be 'the way of the compass'.
    "If you want more fiber, eat the package.· Not enough?· Eat the manual."········
    ···················· Tropical regards,····· G. Herzog [noparse][[/noparse]·黃鶴 ]·in Taiwan
  • bobledouxbobledoux Posts: 187
    edited 2006-08-12 21:58
    My application calls for me to set up my compass unit. I then make readings on a distant moving object. This process will be repeated on a later date but at a slightly different longitude and latitude.
    The comment about moving a degree of latitude or longitude was in recognition that electronic earth field sensors require new calibration with significant longitude changes.
  • TimCTimC Posts: 77
    Try:
    www.robot-electronics.co.uk/
    or maybe in the states at:
    www.acroname.com/index.html
    Should be around $50-$60
    The software side is easy, here is a full workout of what the unit does:
    ' {$STAMP BS2px}
    ' {$PBASIC 2.5}
    '**   CMPS03 Demonstration Software for the Basic Stamp   **
    ' Working on July 31 2006 Tim
    SDA        CON 8      ' Define Data pin
    SCL        CON 9      ' Define Clk pin
    Compass    CON $C0     ' Compass I2C Address
    CmdReg     CON 0       ' Command register
    BearingReg CON 2       ' dir register
    Bearing    VAR Word    ' 16 bit variable for Bearing
    Version    VAR Byte    ' should return low digit number like 9
    LowRes     VAR Byte    ' 8 bit Bearing
       DEBUG "*** Compass Test Program Ver1 ***", CR
        I2COUT SDA, Compass, [noparse][[/noparse]0]
        I2CIN SDA, Compass, [noparse][[/noparse]Version]
       DEBUG "CMPS03 Version: ", DEC version, CR
    Main:
       ' get High Res 0-360.0 scale
       I2COUT SDA, Compass, [noparse][[/noparse]BearingReg]
        I2CIN SDA, Compass, [noparse][[/noparse]Bearing.HIGHBYTE, Bearing.LOWBYTE]
       ' get data on 0-255 scale
        I2CIN SDA, Compass, [noparse][[/noparse]LowRes]
        'DEBUG "Compass: ", DEC Bearing/10, " Degrees", CR ' Use terminal window
       DEBUG DEC Bearing, " Degreesx10, OR 0-255: ", DEC LowRes, CR ' Use terminal window
        PAUSE 1000 ' slow down
    GOTO main
    Regards
    Tim
