COM1 not responding
Well I have been having system problems and reloaded my WindowsXP due to Norton Internet Securitly causing a huge bog down in speed and multiple lockups.
I managed to solve the problem with System Mechanic and I added a Fax Modem to COM1 as I need it for international communications that I occasionally do.
I have had to turn off Norton Firewall and use Windows Firewall for the Fax to work.· After doing so, I no longer have a COM1 in PBasic.
I am thinking of just reinstalling the IDE and seeing if that works, but I may need further help as both the Firewall and the Modem software are involved.
"If you want more fiber, eat the package.· Not enough?· Eat the manual."········
···················· Tropical regards,····· G. Herzog [noparse][[/noparse]·黃鶴 ]·in Taiwan
But I put the Fax Modem in pause on the Printer and Fax folder.
Now, the hardward no longer recognizes it on the COM port list.
All I have is computer-to-computer communications listed there.
I am going to try to reload the IDE as it is easy and it is about the only thing I haven't tried.
It says, 'Can't open COM1, already in use'
Post Edited (Kramer) : 8/12/2006 6:23:00 PM GMT
So, it sounds like you need another serial port.
Hmm. I just tried enabling 'FAX' on my laptop. I have a fax-modem card (apparently) inside this thing -- so dedicating that connection to a fax is not a problem. I'm afraid you may have to delete your fax entry, to free up COM1 for general use. I'd hope that wouldn't be necessary, but none of the options seemed to be "turn off fax service for now".
Now it is working fine, but I have no idea why.
In the wonderful world of automatic updates, documentation no longer exists in any coherent form. One cannot get any overview or autonomy.· Nonetheless, all is well.
I just was able to load a test program and verify my new CANbus board is working properly with the BasicStamp.
