Need Precise Electronic Compass
I'm working on an application that requires a compass. I need to read within 0.5 degrees. The output needs to be linear and repeatable. By repeatable I mean, if I sweep 30 degrees and then return to my starting point, the result will be read as my original heading +/- 0.5 degrees.
The electronic units I've been looking at don't appear to meet these requirements. I'm wondering about mounting a supermagnet on the end of a 10 bit encoder. If encoder friction is low enough the super magnet may follow magnetic North.
I can design my application so the compass apparatus is always parallel to the ground, so tilt isn't a problem.
I can also live with an absolute error or 1 or 2 degrees, provided the readings are consistently linear, or an algorithm can be created to adjust for the error to a final value of +/-0.5 degrees.
The apparatus can be placed to eliminate the impact of ferrous objects. But it needs to be moveable, typically within +/- one degree of longitude or latitude.
Any ideas out there?
http://www.ssec.honeywell.com/magnetic/datasheets/HMR3500.pdf
- Stephen
http://shop.ssec.honeywell.com/shopdisplayproducts.asp?id=6&subcat=12&cat=HMR3xxx+-+Products+and+Accessories
John R.
8 + 8 = 10
A compass is a fundamental tool for them, but the tool has its limits. Anything ferrous that is nearby can throw them off by quite a bit. For example, if you have a roving robot and it passes a metal table leg, you are not going to get a good reading.
When hiking in the woods, metal buttons on a Levi jacket can make for lost woodsman. Or a metal watchband. A good woodsman will set the compass down on a rock and look at it from a bit of distance.
So think about it. Nickel is ferrous [noparse][[/noparse]as in NmH batteries], and their case is Iron [noparse][[/noparse]also ferrous].
If you look at ships and sail boats, even they have compensation for the ferrous metals around them.
That seems to be 'the way of the compass'.
"If you want more fiber, eat the package.· Not enough?· Eat the manual."········
The comment about moving a degree of latitude or longitude was in recognition that electronic earth field sensors require new calibration with significant longitude changes.
www.robot-electronics.co.uk/
or maybe in the states at:
www.acroname.com/index.html
Should be around $50-$60
The software side is easy, here is a full workout of what the unit does:
' {$STAMP BS2px} ' {$PBASIC 2.5} '*********************************************************** '** ** '** CMPS03 Demonstration Software for the Basic Stamp ** '** ** '** ** '*********************************************************** ' Working on July 31 2006 Tim SDA CON 8 ' Define Data pin SCL CON 9 ' Define Clk pin Compass CON $C0 ' Compass I2C Address CmdReg CON 0 ' Command register BearingReg CON 2 ' dir register Bearing VAR Word ' 16 bit variable for Bearing Version VAR Byte ' should return low digit number like 9 LowRes VAR Byte ' 8 bit Bearing DEBUG "*** Compass Test Program Ver1 ***", CR I2COUT SDA, Compass, [noparse][[/noparse]0] I2CIN SDA, Compass, [noparse][[/noparse]Version] DEBUG "CMPS03 Version: ", DEC version, CR Main: ' get High Res 0-360.0 scale I2COUT SDA, Compass, [noparse][[/noparse]BearingReg] I2CIN SDA, Compass, [noparse][[/noparse]Bearing.HIGHBYTE, Bearing.LOWBYTE] ' get data on 0-255 scale I2COUT SDA, Compass, I2CIN SDA, Compass, [noparse][[/noparse]LowRes] 'DEBUG "Compass: ", DEC Bearing/10, " Degrees", CR ' Use terminal window DEBUG DEC Bearing, " Degreesx10, OR 0-255: ", DEC LowRes, CR ' Use terminal window PAUSE 1000 ' slow down GOTO mainRegards
Tim
