Need a ULN2803 like IC for "High Side" driver. Any ideas ?
I need to control the high side of +12volts @ 100mA, from a 0/+5 output pin.
I need to control 8 lines (hopefully with 1 ic).
Any thoughts ?
Cheap 4-digit LED display with driver IC·www.hc4led.com
Low power SD Data Logger www.sddatalogger.com
"You're braver than you believe, stronger than you seem, and smarter than you think" Christopher Robin to Pooh
Any thoughts ?
Do you want to contol them en masse, or individually?
Bruce Bates
Bean.
·· The L293D that is used on the PDB is a push-pull driver, and can control the high side of the devices, however it only has 4 outputs.· There may be a similar chip, however which can control more outputs.· I hope this helps.
Chris Savage
Parallax Tech Support
csavage@parallax.com
That is close enough...
Thanks alot.
Bean.
Chris Savage
