Need a ULN2803 like IC for "High Side" driver. Any ideas ?
Bean
I need to control the high side of +12volts @ 100mA, from a 0/+5 output pin.
I need to control 8 lines (hopefully with 1 ic).
Any thoughts ?
Cheap 4-digit LED display with driver IC·www.hc4led.com
"You're braver than you believe, stronger than you seem, and smarter than you think" Christopher Robin to Pooh
Any thoughts ?
Do you want to contol them en masse, or individually?
Bruce Bates
Bean.
·· The L293D that is used on the PDB is a push-pull driver, and can control the high side of the devices, however it only has 4 outputs.· There may be a similar chip, however which can control more outputs.· I hope this helps.
csavage@parallax.com
That is close enough...
Thanks alot.
Bean.
