Servo running without passing commands
Hello everyone,
We·are using the servo controller with USB interface (#28023) to control·two servo motors. We connected the two motors to the controller board, and·tried to run the motors by sending MATLAB commands but we did not succeed. Yesterday we observed that the motors were running with out sending the MATLAB commands.·After pressing the reset button·the motors ran for 30secs or so and then stopped. Later both the motors started running without sending any commands.
We did not understand any reason for this.
Did anyone face·any problem similar·to this? What might be the reason behind? What are we supposed to do to stop this?
Any·suggestions in this issue would be highly appreciated.
Thanks in advance.
Thanks in advance.
http://www.parallax.com/dl/docs/books/edu/RoboticsV2_2.pdf
Check out chapter 2 starting on page 67.
Hope that helps!
Matt
The motors are working fine and rotating only after passing commands
