BS2SX Maximum Speed for serial communications
I want to built a dmx512 (lighting control) interface.
Getting RS-485 levels is no problem, there are several chips available that will handle that, but I am wondering if the Stamp is fast enough.
DMX is RS-485 and runs at 250,000 bps.
Will the BS2SX (or any stamp) be quick enough to handle this, or do I need more horsepower like the SX micro or Propellor ?
For ease of development I would prefer not to use assembly if at all possible, but any other high level language is fine.
http://forums.parallax.com/forums/default.aspx?f=25&m=132052
Don't visit my new website...
How does the Stamp or SX chip compare to a single processor on the propeller speed ways ??
If the stamp is the same or faster, then this should be doable on a stamp.
·· The Propeller can do over 400Kbps in one COG serially...However the BASIC Stamp wouldn't be able to reach the 250Kbps required for DMX.· I am unsure if anyone has attempted this with an SX or not.· You could post that question in the SX Forum or check SXLIST.COM for any VP that handles high-speed serial.
Chris Savage
Parallax Tech Support
csavage@parallax.com
