circuit termonology — Parallax Forums
circuit termonology
Circuit SmasherCircuit Smasher Posts: 2
edited 2006-07-31 00:19 in General Discussion
I am trying to recycle some sensors I had with an old Lego RCX.· I have a "Short Range Dual Infra Red Obstacle Detector" from a 3rd party vendor and they were nice enough to provide some pin-outs for me, however, I am unfamiliar with some of the terms.
Pin 1 is labeled NC
Pin 2 is labeled VCC
Pin 3 is labeled Ground
Pin 4 is labeled Right Signal
Pin 5 is labeled Left signal
Pins 3, 4, and 5 are pretty straight forward, and I was able to deduce that pin 2 is probably supposed t go to Vdd, but I have no idea what NC (pin 1)·means..?· I've included an image of the pin-out diagram that the vendor gave me (not sure if this is helpful or not).· I realize there are probably going to be many differences running this· with my BS2, but any help would be appreciated.· Thanks!!
IR.jpg 134.9K
    edited 2006-07-30 19:29
    NC = Not Connected.
    (This should have been posted in The Sandbox.)
    edited 2006-07-30 19:33
    As PJ says, "NC = Not Connected" except in a case where you might have a relay providing some sort of switched output.
    In that case NC would mean Normally Closed.· The complement of that would be NO meaning Normally Open.
    Beau Schwabe
    IC Layout Engineer
    This thread is being moved from the BASIC Stamp Forum to the Sandbox Forum.
    Chris Savage
    Parallax Tech Support
    csavage@parallax.com
