varying control of leds
I'm having trouble controlling brightness of led banks , 24 each RGB, each color connected in parallel. Hoped to use digital pots into op-amps - transistors/w feedback to vary incrementally. I'd appreciate any help - which op-amp, dig-pot, transistor tp use. Or where can I look for info? Using LM358, 2N2222, tried 10K and 100K pots, 5 & 12 volts but very little control between LED on - off. Thanks for any suggestions. Al
http://forums.parallax.com/showthread.php?p=591981
Hope this helps [noparse]:)[/noparse]
Vern
Vern Graner CNE/CNA/SSE | "If the network is down, then you're Senior Systems Engineer | obviously incompetent so why are we Texas Information Services | paying you? Of course,if the network http://www.txis.com | is up, then we obviously don't need Austin Office 512 328-8947 | you, so why are we paying you?"
VLG
