Multiple Interrupt Codes
Can you have multiple interrupt codes in the SX?
The reason I ask is because it looks like the Interrupt code needs to be placed at address 0x00 in memory, and all the examples (Interrupt_B, Interrupt_RTCC1, Interrupt_RTCC_2) only demonstrate 1 Interrupt.
I have a project that is using 2 pins as interrupts.· RB.0 and RB.3.· If there is a rising Edge on RB.0, I would like one Interrupt Routine to occur.· If there is a rising Edge on RB.3, I would like a different Interrupt routine to occur.
Also...If I want to use RB.3 in another part of code to perform a different interrupt...
Is this possible?· I am still getting familiar with the SX Chip and need more information.
Shaun
Post Edited (Steel) : 7/21/2006 2:23:44 PM GMT
Shaun
The SX only has one interrupt vector, which is at location 0x00 as you noted. This means that the same code is invoked for any interrupt source you have, and it's up to that code to determine (via software) what source generated the interrupt. One tricky thing is that you can only safely have a single interrupt source without the risk of losing interrupts. Go to question #6 in this FAQ as it explains the issue in more detail:
www.parallax.com/sx/support_faqs.asp
Thanks, PeterM
As Peter explained, the same interrupt routine is called for ALL interrupts.
If the interrupt from RB.0 occurs and the interrupt code is running when the interrupt occurs on RB.3, the new interrupt will not be noticed until the 1st interrupt code is complete. Then the SX will immediately run the interrupt routine again for the new (RB.3) interrupt.
So the 2nd interrupt is not lost, it's just delayed.
Of course your code must handle this situation.
Bean.
Cheap 4-digit LED display with driver IC·www.hc4led.com
Low power SD Data Logger www.sddatalogger.com
"Remember, you are unique, just like everyone else." Unknown.
Actually, the SX can definitely "lose" an interrupt. When an interrupt happens, the first thing the SX chip does in servicing it is to turn off responding to interrupts. If a new interrupt occurs before the current handler finishes executing, then the new interrupt will be lost. Even if you re-enable interrupt servicing as the first step in your interrupt code handler, you could always have an interrupt happen in the tiny space between the first interrupt happening and the servicing re-enabled. Check out the URL in my previous post for the details.
Thanks, PeterM
Ray
Okay, they mean if another interrupt "ON THE SAME PIN" occurs it will be lost. That I agree with.
But if an interrupt on RB.0 is in progress and an interrupt on RB.3 occurs it will be run as soon as the RB.0 interrupt is finished.
As long as you only clear the bit of the interrupt you are processing in the pending register.
Bean.
I'll have to defer to you there as I have never tried to see if multiple bits will stay pending. I assume you are correct.
However, if you have an edge detect as an interrupt source and the RTCC as another interrupt source, my understanding from the documentation is that if either one is being serviced and the other interrupt occurs, that new interrupt will be lost.
Thanks, PeterM
The SX 28 has eight individual PENDING bits for the RB level change detection, but not for the RTCC.
The SX 48 has the RB PENDING bits also, as well as an overflow (same as PENDING) bit on the RTCC. So this device give some more capability in this area.
Cheers,
Peter (pjv)
Therefore, all interrupts do not actually point to the same location.
bongo
I guess you are somewhat right, but perhaps waking up from sleep might not be called an interrupt. Afterall, it WAS sleeping, so we're not really interrupting anything. On top of that, only a true SX interrupt saves the state of numerous registers, and restores them on exiting interrupt. Reset (wake up from sleep) has no such ability. So, perhaps they are very different afterall.
Cheers,
Peter (pjv)
bongo
