Using 2 or more FullDuplexSerial — Parallax Forums
Kevin L.Kevin L. Posts: 10
edited 2006-07-21 13:27 in Propeller 1
If I want to use two or more serial ports, can I use the FullduplexSerial.spin Object as-is? Or do·I need to·modify it so it uses different memory space for each serial object?
    If you declare two objects (any object), they will get a different memory space. so ...
    OBJ
      ser1 : "FullDuplexSerial"
      ser2 : "FullDuplexSerial"
    This gets you two independent serial ports, but only one copy of the code.
