Using 2 or more FullDuplexSerial
If I want to use two or more serial ports, can I use the FullduplexSerial.spin Object as-is? Or do·I need to·modify it so it uses different memory space for each serial object?
This gets you two independent serial ports, but only one copy of the code.
