Basic Stamp and a 25 Amp Relay for a big DC motor . ( not solid state relay) — Parallax Forums
JoeJoe Posts: 184
edited 2006-07-20 19:49 in BASIC Stamp
Hi,
I am looking for information about an standard 25 Amp
relay ( not solid state).
I need to drive it using a basic stamp 2
Is a 2N2222 transistor enough ?
Is it necesary to add a diode or a chip
to keep basic stamp working properly?
The coil consuption is about 350 mA.
Any information will help me.
  • Beau SchwabeBeau Schwabe Posts: 6,574
    Joe,
    Double check that your drive current is actually 350mA for your relay... seems a little low.
    Here is a link that should help you determine if a 2n2222 is going to be enough.
    Substitute your Relay for the Motor.
    Don't get HOT choosing the wrong transistor
    Beau Schwabe
    IC Layout Engineer
