Propeller gonna' hurl
cgracey
Try·this on the Propeller Demo Board with headphones, or just put some RC integrators on pins 10 and 11 and listen in stereo. Maybe somebody can make a recording of this and post it on this thread.
Chip Gracey
Chip Gracey
This will add a truly crazy behaviour to robotic projects, for certain. Until Propeller, even walking and beeping at the same time was a challenge for my robots, let alone walking and hurling along the way.
Thanks for sharing...
Are you Propeller users out there very intrigued by a speech synthesis object?
Chip Gracey
Seriously, yes. I can see where this "hurling" is going. The underlying phonemic qualities are pretty convincing!
Chip, that's great! Although I'm currently using the Propeller for robotic control, after hearing (and watching) the Hydra demo and listening to this I see the audio possibiliities of the Propeller are very interesting ...
I've been making weird lofi chip/glitch "music" (using the term generously) for a while now, but mainly using software (favorite tool: Buzztracker!) and a couple of drum machines, but I have a nice collection of old toy keyboards, some of them modified ("bent", see www.anti-theory.com/soundart/circuitbend/).
So I have been pondering the idea of adding some Propeller-based noise making device. Maybe something along the lines of the Avrsyn, ( www.elby-designs.com/avrsynth/avrsyn-about.htm) which uses an Atmel avr along with a rudimentary DAC made out of a 8 resistors in parallel.
One thing I've noticed looking at the schematics for the Propeller demo board is that there's no DAC, but rather a couple of pins going directly to the MAX4411 headphone amplifier. So, you're just using square waves, or am I missing something?
Chip Gracey
Thanks.
Post Edited (T&E Engineer) : 7/20/2006 2:14:03 PM GMT
This is neat. I can see this becomming something lilke a text 2 speach hardware device as well...
Propeller + Hardware - extra bits for the bit bucket =· 1 Coffeeless KaosKidd
Ah, I see. Hm, I don't know much about analog electronics. Will have to study it.
By the way, Bambino, that sounds interesting. If you make something cool please let us know!
Rob7
someone might want to take a look here. I've been musing that it might be a nice problem (when I got better) to try and convert this for a Prop--
www.romanblack.com/picsound.htm
and see if this is adaptable. Spend some time there- the "1 1/2 bit" sound is pretty good!
The advantage I see is that the MP3 to sound to bit stream conversion program is already written. there are also clues for writing the playback program and for storing the files in a separate eprom.
Anyone with an amazing tolerance for tedious work might be able to construct the whole list of phonemes for a speech module.
The·"1 1/2 bit" coding is pretty clever. I think it is very difficult to mix samples (Except for analog mixing with resistors), but the 1/8 compression is very impressive.
I was thinking about ADPCM (1/4 compression) which is open source. ADPCM is signed 16 bit, this makes the algorithm ideal for sample mixing (sound effects, etc.)
I could not find detailed description about the PWM or DUTY cycle mode of the counters. I could not find a commented·example to set the PWM frequency and duty cycle. (Or any any other setup of the counters for sound reproduction)
I don't think PWM is involved. I think it's just a serial readout of the bit stream of the information stored in the EEPROM. The question then is what rate to playback. I figure that depends on the cap and resistor values analogue integrator you use and the playback rate.
I'll admit info is a little sketchy and I could be totally wrong. Roman invites inquiry on his site.
By the way, Bambino, that sounds interesting. If you make something cool please let us know!>
Mother board fried last night, This heat is killing everything but my pepper plants.
Thank God for dual hard Drives!
Definetly a E3 (Electronics Engineer Extrodinare!)
"I laugh in the face of imposible,... not because i know it all, ... but because I don't know well enough!"
Dave Evartt
People don't hate computers, they just hate lousy programmers.
http://wehali.com
ALIBE - Artificial LIfe BEing. In search of building autonoumous land robot
http://ALIBE.crosscity.com/
http://fstop.crosscity.com/
http://icar.crosscity.com/
I am indeed intrigued by a speech synthesis object.
Paul Baker
