you guys make this too easy!
I seldom post but I had to congratulate you guys on a project I completed in less than 15 minutes! My brother owns a machine shop and was telling me the other day he needed to find the actual spindle RPM of one of his mills. I remembered a blurb form Ken Gracy a few months ago on doing exactly that. Sure enough he provides the circuit and BS2 program for a mill RPM indicator. I didn't want to use a $40 BS2 when I had a couple of the SX-48 project boards handy. Also I had a handful of·Terry Hitt's·4 digit SPI displays. Erasing the 'main' block of code in the Terry's SX display example and replacing with 3 lines from Ken's program plus 2 declarations and the thing worked the first time in less than 15 minutes!! This was also using a completely different Hall Effect device but wired identically to Ken's circuit. It's going to take me longer to mount the thing in a case. Nothing has worked that easy and quick before!
Bean.
Cheap 4-digit LED display with driver IC·www.hc4led.com
Low power SD Data Logger www.sddatalogger.com
"I'm a man, but I can change, if I have to, I guess" The Red Green Show
That's fantastic. Now that SX/B has come this far, I wouldn't use a BS2 for that project either. Your message is just a reminder to me that I need to get some more machining time in! Seems that lately we've had too many other projects at Parallax. I've been dreaming of building another robot for over a year now.
Did you find that the magnet had to be mounted really close to the MX90217 sensor? Did you mount the magnet on the top of the spindle?
Ken
I am rapidly coming to the conclusion that my only need for C is to read examples from other manufacturer devices that I want to import into an SX or a Propeller.
Bean's displays are a real bargin. I just went shopping for some 2"x3" printed circuit boards in a small quantity [noparse][[/noparse]about 25] and the prices for the boards alone would be more than the whole device!
"If you want more fiber, eat the package.· Not enough?· Eat the manual."········
One thing I learned the hard way...Never tell on yourself...
Of course I guess it's really more bragging if you say you did it in a couple minutes...
Then you might run into the problem I have at my work...Do something once, and you're expected to do it all the time...
Pictures...Pictures...We want pictures...
Bean.
I would like to see pictures also, and how you modified the code.
Lynn
