Where is the program stored in a BS2?
RDL2004
If I have a BS2 (OEM version) and I load a program into it, is the program only in the eeprom or is part of it in the interpreter chip?
In other words, for a project where there will be multiple copies and only the interpreter chip (the PIC16C57), the eeprom, and the resonator are needed on the board, can I just program multiple copies of the eeprom?
I suppose I could just try it and see, but currently I only have 1 of the PICs.
- Rick
- Rick
This will let you prototype your design with the BS2 OEM and when all is finalized, build the BS2IC-DIP based project WITHOUT a serial programming interface, and just move programmed EEPROMs from the BS2 OEM to the project board.
I wouldn't connect that if I were you...
It'll save me from putting a ZIF socket on my BS2 oem board.
- Rick
http://forums.parallax.com/showthread.php?p=567989
Chris Savage
Parallax Tech Support
csavage@parallax.com
