"No BASIC Stamps found." :(
I'm sure we've all gone over this a million times but I'm hoping maybe there's a simple fix for this.
I tried compiling a test program for my BoE BS2 and got the "No BASIC Stamps found." error.
Loopback and Echo show Yes in the status window.
I double-checked the board and cable: everything is proper. I've got a 6V 300mA power supply plugged into the BoE. The green LED is on. I also tried with a battery but get the same result. I've verified that there is voltage to the BS2 (4.96V on Vcc).
I checked my COM1 port configuration: it's set for 8N1 with hardware flow control (I don't believe the baud rate matters but for the record I have it at 115200). I've tried it with software flow control with the same results.
Yes, I'm using a real, honest-to-Gawd serial port on a laptop. I verified that it's properly configured and enabled in the BIOS: it is.
I installed a serial port monitor (Free Serial Port Monitor by HHD Software => http://www.serial-port-monitor.com/) and I see data going to the BS2 but no data coming back. The editor is apparently trying to send the byte stream 00 42 00 65 00 58 00 50 00 49 00 54 (BeXPIT).
I used Hyperterm with a null modem adaptor and a bridge wire from Rx<->Tx to verify physical loopback out the serial port: characters get echoed back properly.
I downloaded and installed the latest editor from the Parallax website (v2.2.5).
I'm running Windows XP v2002 with SP2.
Any ideas?
Thanks!
Any ideas?
Thanks!
·· The most common problem with laptops using serial ports is the on-board FIFO buffers.· Have you tried disabling them in your Advanced Port Properties in the Device Manager?
Chris Savage
Parallax Tech Support
csavage@parallax.com
Yes, I did try disabling the FIFO queues but that didn't help.
I'm trying to think if there's anything else I've tried but I think that covers everything.
Thanks for the quick reply. Hopefully I can still get this to work.
·· Are you sure you unchecked the box labeled, "Use FIFO Buffers?"· Changing the sliders won't help in most cases, and also be sure you affected the COM Port that the BASIC Stamp is connected to.· Also, do you have any kind of adapter inline with the cable?· Are you using a straight-through serial cable?
Chris Savage
In the meantime, I installed the editor on my desktop machine and am having the same problems. Unless a cable change fixes anything, I'll assume the BS2 is bad(?)
Thanks!
Chris Savage
Chris, thanks for the quick responses.
sometimes you have to change the COM Port . I had a fine time....once i changed the Port setting. Also, some laptops not allow you to download even if you do change the FIFO buffers.
As Chris suggested, I'll send mine in for repair.
Thanks!
