New ideas..
since im finished with the book "whats a microcontroller" and now im tryiing to think of some ideas of some things to make with the parts i have.. if anyone has some ideas without going into detail so i have somthing to work at it would be great! thanks also i have alot of experience in c++ so coding standards you shouldnt worry about.
- Stephen
Try building the Knight Rider light bar or try and sequence·the LEDs like christmas chase lights. Make a LED firework for the 4th.
I think I saw something on using an LED as a input device I think it was a non touch input device (sounded cool).
If you want I will do some looking to see if I can find the link or book or PDF.
You'll have to play around with some of the timing numbers, but you can get it to make some pretty cool "robot" beeps and boops fairly easily.
Also, there is no reason that you can't build a robot other than the Boe-Bot with what you have. You'll just have to be creative, and maybe buy a few parts.
http://www.robotstore.com/download/protobot.pdf
I've got one started at home.
- Stephen
