ordering single quanitys of ic's
hi all,
anyone know where i can order single quanitys of a a/d converter chip ?
i know parallax has the maxim 1270 for about $30 , however i dont need 8 channels...
the maxim 1272 has one channel, 12 bits , low volts and spi, and most important allows me to measure a 0-10vdc input.... sells for 6.75, if i want to buy 1k
so... whos your fav non parallax chip retailers ?... this a/d will be used by a proppellor, so the 3 v ones are preffered.
dan
dan
- Rick
mouser didnt have maxims when i looked, however i prolly need to widen my search a triffle... havent looked at newark either... thanks
dan
You can make a virual A/D out of an SX, two resistors, one capacitor, and 8 or so lines of code. Beside the SX, which you may already be using, about 5 cents!
Cheers,
Peter (pjv)
...And go figure, you just don't see those in the trash and fixable all that often.
Yours, Tom Perkins
· What's it matter where they're located?· Everything goes by common-courier and gets delivered to big or small, regardless.
· 0-10V input?· Well, that's what scaling resistors (voltage dividers) are all about.· Why paint yourself into a corner?
· Post Edit -- didn't find a max1272 at mouser, digikey, jameco, or newark.
Post Edited (PJ Allen) : 6/20/2006 11:46:12 AM GMT
If you have a part number and are looking to source it, here is a very handy search engine which will search 22 different distributors and resources concurrently:
http://www.findchips.com/
Bruce Bates
<!--StartFragment -->
https://shop.maxim-ic.com/storefront/welcome.do#
(fourth item down in the left side menu)
Post Edited (RDL2004) : 6/20/2006 1:08:35 PM GMT
thanks for the pointer for the findchips thou..
dan
stand back! I have a slide rule and I know how to use it!
i recomend it.. microchip is similar.
3D & 2D Design - Technical Documentation
www.robertguyser.com
NerdMaster
For
Life
Life is one giant teacup ride.
