Picture for Qt113 Schematic — Parallax Forums
cdubcdub Posts: 26
edited 2006-06-15 21:53 in BASIC Stamp
Is there a picture of how the circuit will look on a homework board?
I can make out most of it, but need assistance figuring out how Sns1 and Sns2 numbered 6 and 7 respectively on the qt113 should be connected. And also 10nf.
Cdub
  • Tricky NekroTricky Nekro Posts: 218
    edited 2006-06-15 21:09
    I would add a 100nf or less connected to the ground for the electrode... No connection but when you touch the electrode you may need some times to also touch the one lead of the cap... (If you do not "ground well" , sorry greek expration but I don't know the English one)
    Provas, Greece
    BTW: Nothing special about the circuit it's a easy one...
    -Rule your Destiny-
    --Be Good. Be Bad. Be Provas--
    (Well, that was certainly confusing...)
    Put one end of the cap into the slot of·pin6 and the other end to the slot of·pin7, then put one end of the 100ohm resistor into the slot shared by pin7 and one end of the cap, the other end of the resistor gets pushed into a row all its own.· Guess it's a touch-switch.
    Post Edit -- picture uploaded
    Post Edited (PJ Allen) : 6/15/2006 9:23:20 PM GMT
    395 x 293 - 16K
  • cdubcdub Posts: 26
    edited 2006-06-15 21:23
    Thank you for the explanations.
    When you say the same slot, would that be the empty slot next to it on the same row?
    Also, will one end of the 100ohm resistor stick up in the air to be touched?
    edited 2006-06-15 21:25
    Hang in the air or place in a slot (slotted means less movement, of course.)
    Please see the picture that I added to my previous post.
    Great! A picture is worth a thousand words. Pardon my weak electrical skills.
    Thanks again!
    Cdub
