Picture for Qt113 Schematic
Is there a picture of how the circuit will look on a homework board?
I can make out most of it, but need assistance figuring out how Sns1 and Sns2 numbered 6 and 7 respectively on the qt113 should be connected. And also 10nf.
Cdub
Cdub
Provas, Greece
BTW: Nothing special about the circuit it's a easy one...
-Rule your Destiny-
--Be Good. Be Bad. Be Provas--
Put one end of the cap into the slot of·pin6 and the other end to the slot of·pin7, then put one end of the 100ohm resistor into the slot shared by pin7 and one end of the cap, the other end of the resistor gets pushed into a row all its own.· Guess it's a touch-switch.
Post Edit -- picture uploaded
Post Edited (PJ Allen) : 6/15/2006 9:23:20 PM GMT
When you say the same slot, would that be the empty slot next to it on the same row?
Also, will one end of the 100ohm resistor stick up in the air to be touched?
Please see the picture that I added to my previous post.
Thanks again!
Cdub
