some dumb transistor questions
I want more power out of my BS1, so I figure I should use some transistors, but I have a few questions that I can't find answers too (I've google searched for quite a while now)
How can I tell how many amps I can get out of the emitter?· I need about a 1amp 12volt output activated by a BS1 pin, can I do this with just a transistor or do I need a relay fed by a transistor?
thanks!
thanks!
· The maximum current draw that you can expect from a transistor is defined by IC (MAX).· That must be tempered by PD, which is total device dissipation.
