trying to hook a little speaker up to BOE breadboard
I'm new to robotics and not very well versed in electronics. i have a boe-bot and i've gone through the tutorial and am looking forward to experimenting with all kinds of things. but while i'm waiting for my next paycheck, i thought i'd try to hook up this weird little voice box to my boe-bot; everytime the button is pushed, it says "I LOVE YOU, I LOVE YOU" in this super creapy voice--it's meant for stuffed animals. anyway i figured if i just sealed the button closed and attached the battery wires to the breadboard it might work whenever i send a high signal to that pin, but no. it runs on 3, 1.5v batteries, so i guess it needs 4.5v? i tried setting up a resistor/capacitor circuit and using the PWM command, but call me a nut, i cannot figure out the circuit diagram under PWM in the syntax/reference manual.
any advice?
thanks,
ben
any advice?
thanks,
ben
I doubt that the "voice box" is complaining about the voltage, 5V should be just fine.
The problem is that the "voice box" is probably not getting enough current.··
PWM in this case is not the way to go here.··
As a quick check, try connecting the + of your "voice box" directly to VDD (+5V) just
to see if it comes on.· Make sure that the - of your "voice box" is connected to VSS also.
If this test works, then you may just need a NPN transistor (2n3904) connected to your
"voice box" so that it gets just a little bit more current than the onboard BS2 can supply.
Beau Schwabe
IC Layout Engineer
Ben
P.S. I don't know what a relay with a 5vdc coil is. something i have to order? i'm attaching the code i've been trying.
ben
